Ok i was doing a little color on my manifold cover. So i took it off and started to paint it. I let it dried and then i put it back on. Looked really good.so i started to tighten the bolt. then snap it broke. i removed the cover, and the bolt is down there deep. So i go to a automotive store and he told me it was easy to remove. All i need is a EZ-Out bit. So i go to the store and a ask the guy how to do it ,then he told me it was EASY. So i go home got out my drill and started to drill a pilot hole and then i started drilling and then when i got done i see that i drilled in the side of the bolt in to the manifold. So right about now im freaking big time. So i put some gasket maker around the side and put the manifold back on and tighten the 2 other bolts. it sounds ok but when i rev the engine and it like it almost dies and then starts back up again. Well i think it the oil perssure,but i have no clue.
Well my question is. what should i do. what can a professional do, and how much do you guy/girls think it well cost me.
Well thank for taking ur time read me storie and and anwswer well help.. THANKS!!!
