1 - 6 of 6 Posts
Hi..
the airbag light on the dash board keeps blinking...
3 times ----- pause ----- 2 times..
i am sure this is a diagnostic code. Can someone tell me what it means
and should i bring it to the dealer.... ??
Thanks
The dealer or someone else who can test the air bag system to determine what is at fault. I am a firm believer in airbags (tried them out once or twice, nice, very nice) and the whole system has to function properly for them to do their job. Usually it is just a sensor that is bad (the systems are actually pretty simple if you look at them) and they aren't that bad to replace. Try unhooking your battery for 2 minutes and then hooking it back up. You never know, it may just be a hiccup left in the system from a bad day.
code 32 = Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
Which translate into loose conection or faulty airbag, or safing sensor. in either case your airbag will not deploy if you are in a crash with this condition. The syten must trip two sensors before the airbags deploy. The sfing sensor provides the + power to the airbags. on some occasions hard braking is enough to set off the safing sensor. the bags won't deploy though unless the crash sensor is also activated providing a ground to the airbag and thus deploying it. It takes conciderably more force to trip a crash sensor. Something around a head on impact into an imovable object at speeds around 20-25mph or higher.
thank you .. this will give me a place to start looking.. :p
1 - 6 of 6 Posts
