Ok.
The most expensive thing for air ride is the Bags or Cyls obviously.
Bags = $780 usd /4
www.universalairsuspension.com
Cyls = $410 usd /4 Shipped from "Section 6"
Cyls take more fabrication than the UniAir bags....so they bothe about even out.
As for everything else.....(cyls)
Ball/Socket top pivot = $89 usd/2 (a must!)
Hyme Joint = ~$32 usd/2 (for the rear or fab your own) - Showtime Hydraulics
3/8" SMC valves = $139 CDN/2 shipped - Team Pneumatik in Quebec
Home Depot for lots of compression fittings and copper lines (don't forget the inner sleeves)
Switches (momentary Toggles) $5 CDN each - Home Depot
Check valves and inline separators from "Princess Auto"
Lots of wire....Princess Auto or a Surplus store
Guages - APC or any hardware store (0-160 psi range)
Pipe Bender - Princess Auto.
Tank - Canadain Tire/Princess Auto or where ever.....just look @ the pressure ratings
You will have to make the top pivot bracket assembly from scratch with the ball/socket joint to take the stresses off the cyl itself or you will end up with a sheared piston rod (MIG and Drill press and tap/die set needed)
Same with the rear Hyme joint top bracket.
Lower brackets can be milled out on a lathe to go into the bottom of your old struts or you can weld up your own bottom brackets)
The reason I asked about the A/C is that you can use it as a compressor for running air. You'll need to re-do a bunch of the lines and get rid of your condensor and accumulator and pressure switch (it's set for 400 psi and over)
Get a pressure switch for a regular 120/240 volt compressor that is set (but can be adjusted) for on 100 and off 125 psi
That will be used to control the clutch on the A/C comp when your tank gets low.
Air bags are an easier setup since you can use your stock struts (modified....still need a MIG)
This is better for the "off roading" application where the cyls are good for show. But the bags do cost more unfortunatly
also....
2 Valves = All Up/Down
4 Valves = Frt/Back/Up/Down
8 Valves = F/B/S/S/Up/Down
4 Valves and 2 Spool Valves = F/B/S/S/Up/Down/3 wheel
3 wheel can be done with air bags....but not all that well as Cyls with Spools can.
If you haven't ever really played with your suspension before.....the Bags would be the way to go. And it is possible to get a Full Air system going for under $1000 installed.
I had the option of doing it under that $1000.....but I went a bit further........
