1 - 4 of 4 Posts
I HAVE A 91 ESCORT GT 5 SPEED
MY CURRENT MODS ARE
2 1/4 PIPING FROM STOCK EXHUST MANIFOLD BACK WITH ONLY A HIGH FLOW CAT , FLEXER= FOR EXHUST TO FLEX AND A PREFORMANCE MUFFLER.
OPEN AIR FILTER WITH A 1987 MAZDA RX-7 MASS AIR METER. A/C REMOVED AND MINOR STUFF .
KNOW MY CAR IDELS AT 700 RPM AND WHEN I SHIFT IT SOMETIMES WILL BOG DOWN WITH A HESATATION ALSO I HAVE A HESATION WHERN I GIVE IT GAS FROMN A DEAD STOP.
LOOKING FOR HELP ON THIS ONE.
I DON´T HAVE A AIR FEUL RATIO GAUGE TO FINE TUNE BUT I ALSO THINK IT COULD BE MY ALTERNATOR AND OR MY CLUTH,IT IS PRETTY CLOSE TO BEING GONE.
ANY INFO TO HELP OR IF THIS HAS HAPPENED TO U WITH YOPU SCORT.
THANKS RYAN
First Question..... What is an exhast flexer???? Seeing as how exhast is a gas I can´t see where it would need help flexing. But seriously... When was the last time you checked your ignition timing? Some people make mods to their car and forget that increasing air flow, and/or fuel will mean you engines timing needs will change too. May need to advance or retard it just a tad to get the idle right again. The only way I could think that a bad cluch would cause a low idle is if it weren´t totally disengageing from the flywheel, but you would be able to smell cluch after idleing at a stop light for a while if that were the fact. Also while you are checking the timing go ahead and take a look at the plugs and wires too. Let me know what happens.
1 - 4 of 4 Posts
