air bag light not working | Ford Escort Owners Association (FEOA)
Discussion in 'Safety & Security' started by Hany, Apr 27, 2013.
  1. Hany
    Hany FEOA Member
    29
    8
    153
    I have a 98 wagon and i noticed that the air bag light in the cluster doesn't work at all when i switch the ignition key, i thought the bulb was bad so i replaced the bulb with another one that's working and got no light, then i replaced the cluster with one from a junkyard to add an RPM tachometer and still no light at all.
    is the SRS system non-functional? is it a blown fuse?
    could anyone guide me on how to check and troubleshoot the SRS system and wiring.
  2. Jaschiero
    Jaschiero FEOA Member
    207
    13
    48
    Newport News, VA
    If it were a fuse or something, the light would be on to warn of an issue with the airbag, perhaps a bad ground to the bulbsomewhere?
