I noticed my motor was a bit "limp" on the bottom end - so I removed and cleaned my entire intake - AEM dry flow - and so on -
then I thought, hmm, perhaps my timeing belt is a bit stretched, crank key may be worn a 1000th - perhaps I should advance my cam timeing 2 degress - so I did - low and behold, my power is back.
EDIT: Price $129.99 - I need atleast 25 orders to get the run done.
How many people would be interested in buying 1? Link: http://www.escortfocus.com/html/cvh_cam_gear.html
1.9(after 4/91) - 2L(SPI) - works for both - will not work on Zetec
I feel some of our low end lag may be compensated by an Adj cam pulley. As the timeing belt stretches it WILL throw cam timeing off a bit - this pulley will compensate for that and keep the motor in time. Those that are looking into "cam'ing" their motor will need one of these aswell since a grind profile WILL throw off top end timeing.
post any questions here.... there is a group buy thread for this in "Group Buy" forum - also found here:
http://www.feoa.net/modules.php?name=Fo ... ic&t=61048
Matt.
edit: buy page for cam gear group buy:
http://www.escortfocus.com/html/cam_gear.html
Matt.
