While I am full of questions heres one more, my 95 gt did not come with with cruise control and I was considering adding it if its somewhat easy. I searched but no real good info could be found. Can I use stuff from 1.9 liter escorts as they are more common in junkyards and what all is needed to convert. Also I know controls are on steering wheel so Would I have to swap whole steering column?
Also I have an odd problem with my ac compressor. The motor I was told had been swapped in my escort when old one blew up and Iw as told ac did not work. So I investigated and saw the plug for compressor was not plugged in. Once plugged in I kicked on ac and compressor kicks on and off every 3-4 seconds consistenly. It makes car hesitate horribly while driving so I disconnected it. Any ideas where I should start looking?
