Accessory bracket | Ford Escort Owners Association (FEOA)
Accessory bracket
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by Gamer92, Apr 16, 2015.
  1. Gamer92
    Gamer92 FEOA Donator
    3,424
    973
    263
    Southern Indiana
    Did any third gens, come with a bracket that only had alternator and power steering? Sort of like how earlier generations had specific brackets
  2. 22732
    22732 Guest
    I know there were some third gens that came without a/c from the factory although rare. It would probably be a hard find. I remember my first gen escort only had an alternator bracket since it was the fully stripped base model without ps or a/c. Was neat how basic that car was at times.
  3. 98_Jim
    98_Jim FEOA Member
    385
    16
    268
    It's been a while since I've dug around the water pump, power steering, compressor area (so I may be wrong), but I seem to recall that the A/C compressor is bolted directly to the engine block and not secured by any bracket. (Someone correct me if this isn't right).
    You can purchase a non-AC accessory belt for the Escort at just about any auto parts store. It will bypass the AC compressor pulley.
    I bought one last fall when my compressor clutch bearing failed. The non-AC belt clears the compressor pulley so you don't have to remove the compressor if you don't want to.
    I plan to replace the compressor, the pulley and the dryer in the next few months before the really hot weather gets up to where I live.
    22732 likes this.
