ACC wire | Ford Escort Owners Association (FEOA)
ACC wire
Discussion in 'ICE (In Car Entertainment)' started by littlestatey, Dec 28, 2012.
  1. littlestatey
    littlestatey New Member
    6
    I was installing a new head unit and found the ACC wire to be bad. How do I replace this wire, where does it run?
  2. neuspeedescort
    8,123
    98
    348
    wenatchee, wa
    if you want to make the fix simple tap off the cig lighter.
  3. littlestatey
    6
    Will this allow the radio to shut off with the ignition?
  4. pextor
    pextor Moderator Staff Member
    5,837
    749
    Lancaster, pa
    yes, the cig lighter is a switched power source.
  5. neuspeedescort
    8,123
    98
    348
    wenatchee, wa
  6. littlestatey
    6
    Thanks, I'll give it a shot and let you know
  7. littlestatey
    6
    Hey, it worked out great. The wire is a pain to get to but it works! Thank you.
