1 - 3 of 3 Posts
AC worked fine one day--next day blows warm on AC or Max AC settting. Reading other posts it appears 1st suspect is the Constant Control Relay Module. Are there other parts to look check too???
Thanks!
John
Former Escort Owner
Next time it quits working, check the clutch on the end of the A/C compressor. It should spin with the pulley. Depending on the temperature outside, it may kick on and off, more often if it's hot outside.
Casey
1 - 3 of 3 Posts
