A favor for those with GT's and a Wideband | Ford Escort Owners Association (FEOA)
Discussion in 'Engine Swaps' started by uglyducklingescort, Oct 20, 2008.
  1. uglyducklingescort
    uglyducklingescort New Member
    997
    Tulsa, OK
    Let your car warm up, what is your AFR at idle.
    Secondly with the car running unplug the Vac line to your FPR let it run for a bit with the hose plugged with your finger. What is your AFR at this point?
    -Steve
  2. therieldeal
    therieldeal FEOA Member
    8,622
    19
    338
    Northeast CT
    whyare you worried about afr with the fpr unplugged?
    i need aroudn 13:1 afr for a smooth idle.
  3. uglyducklingescort
    997
    Tulsa, OK
    think I am having issues with it. I can idle fine at 14-15 smooth as hell. But every once in a while seems like it gets erratic. Also have problems with the fuel system getting a vapor lock when it is really low on fuel. And it is not a leak near the fuel pump.
    Most people hit a corner loose power and regain it. I don't I completly die and I either have to wait a few minutes and try again or remove fuel line from the fuel pump.
    When I unplug the FPR at idle the idle should also change as it should start to load up, but nothing happens.
    -Steve
    I also don't have the tools thatt I used to so a fuel pressure tester, or a vac pump are out of the question.
  4. therieldeal
    8,622
    19
    338
    Northeast CT
    weird. i get misfires if i try to idle that lean, most other people i have talked to have experienced the same.
  5. uglyducklingescort
    997
    Tulsa, OK
    seems mine runs worse when i am in the high to mid 13's at idle. I also don't have my IAT hooked up and is completely blocked off.
    -Steve
  6. therieldeal
    8,622
    19
    338
    Northeast CT
    IAC or IAT
    two completely different things
  7. yunvmyegt
    yunvmyegt New Member
    274
    boston, ny
    i dont have a wideband, but im curious to see what your issue is, my auto 95gt does the same thing, i never have figured it out, my stick 94gt was perfect , i could do 90 around a turn with no gas...lol... oh well i wanna see why your appears to do teh same as mine tho.... i home my other 95gt im gettin doesnt have that issue....
  8. uglyducklingescort
    997
    Tulsa, OK
    stepper motor is not hooked up..... at all completely plugged off. But even still it would have no effect, not even sure why I added that.
    As for
    There are many common problems with this but most regain power. There are numerous write ups on here about these, as they will not be covered here for this issue. So just to make sure that you have the others covered.
    -Steve
  9. yunvmyegt
    274
    boston, ny
    ive changed sending units,pumps, got rid of the pulasator inline of the pump and unit, the baffle inside the tank is fine it just vapor locks hardcore under a half tank, fuel pressure is also fine b4 hand no bumps.....
  10. cis2711
    cis2711 New Member
    768
    My gtx idles at 1200-1500rpms depending on the temp. and its A/F ratio bounces between 14 and 15 and it misfires intermitently(sp). Once you get into the throttle it runs fine on all four cylinders but at idle it stutters here and there. I might try adjusting the VAM rich at idle a few clicks to see if this changes.
  11. uglyducklingescort
    997
    Tulsa, OK
    off topic but why do you have it idling so high?
    -Steve
    I am going to try another fuel pump assembly unit tomorrow and see if anything changes.
    -Steve
  12. uglyducklingescort
    997
    Tulsa, OK
    Today I changed the entire pump assembly from a 96 LX, using the stock pump from that car and the problem has gone away, or so it seems at this point. Looking at my 255 pump it looked as if there was a screw or something that went in to top of it that was not there anymore. I dunno, when we have a warmer day I am going to go out and make sure that it was the pump and not something else.
    -Steve
