1 - 2 of 2 Posts
1. how do you remove the plastic finish panels next to the rear windows on a non-hatchback sedan?
2. can the window and rear window trim be removed without taking the glass out?
most of the interior is held in by metal clips that just pop out when you pull, and these little plastic pop-clips that you have to pull the centers out of and they basically just fall out. Basically, if you can't see a screw holding it in, then there probably isn't one.
1 - 2 of 2 Posts
