1 - 5 of 5 Posts
alright i have my lxe... and it has a problem with the rear tranny mount, i have some questions.
1: does anyone know why if i go to get the mount the part is dependant on like the 8th vin? i would assume it would be only different from mtx to atx but that is one of the first things put into the computer. and since my tranny is a junk yard tranny i dont know what vin it is.
Because of this mount i have torn the bushings holding my shifter ball up. recently i have been hitting second kinda hard and it really is jerkin my shifter around so now i need to make a trip to the junk yard for a new linkage assembly. isnt too much of a probem luckily because i will have to motor out thursday :)
2: If i can get a new mount in time or not i would like to fill this mount especially since i will be turbo in a couple months... id probably be turbod now but i have had to replace the tranny and now motor since i started payment on the turbo setup :( , anyway does anyone know what kinda store i could get a polyurethane mix or somethin where i can mix it up and fill the mount? i know i can get the inserts but i have ZERO cash till wednesday because im buying the motor tomorrow and then by wednesday i will have no time to order inserts and get them here in time.
thanks alot guys/gals
-andy
Discussion Starter · #2 ·
are you kidding me... no one knows? come on guys
any tranny mount for a 5speed 91-96 egt will work on the rear. some of the fronts on newer escorts are oil filled mounts and are a bit bigger.
thanks for the info guys... a bit late now but its good to know. i wanted to know while i had my motor out but i am just stuck with the broken mount for now. again thanks for the info
1 - 5 of 5 Posts
