I've had a catastrophic A/C compressor failure.
Bought a remanufactured A/C compressor and installed with with new lines, new condenser, new drier and new orifice tube after flushing the evaporator. It was running at 380psi+ on the high side on idle. After giving it some gas it would go beyond 400 and shut off.
Took 0.5lb of freon out thinking that it may be overcharged but still ran at 350psi.
Exchanged the compressor for a new unit. Put it in after flushing all the lines, condenser and evap and installing new orifice tube and same thing again. It is running at 350-375psi on idle and even higher under throttle.
Does anyone have any clue on what is going on here? Anyone had a similar issue? Thanks.
