My daughter has a 99 ZX2 where 2nd gear seems to have gone away and the O/D appeared to have stopped working. When I say stopped working I mean that the tranmission doesn't seem to shift into O/D because at 60mph its cranking 3500 rpm's and as soon as you lift off the accelerator it drops to idle. This seemed like a torque converter lockup issue but I scanned it and got a P0761 code which states
P0761 Shift Solenoid C Performance.
Fluid level was fine and fluid condition was fine. I dropped the pan and everything looked great. Inside of the pan was very clean, nothing sticking to the magnets inside the pan.
Given the code I decided to change the 2-3/3-4 solenoids (not for the faint hearted) along with the 1-2 solenoid to try and improve the 1-2 shifting smoothness.
Got this all done and the P0761 code is gone but I still seem to have no O/D or 2nd gear. The next thing I am wondering if I should replace is the TCC Lockup Solenoid?
Has anyone else had this wonderful experience. Any ideas or help are greatly appeciated.
