1 - 10 of 10 Posts
Discussion Starter #1
hello im seeing that it says to remove the sway bar link from the escort gt for better traction. should i do the same on my zx2? any other good tips would help.....what should i run for tire pressures?205/70r14s on the right side and 195/65r14s on the left. thanks alot guys
kyle
what size track do u run at? i ran a 2001 zx2 last year it wasnt too bad of a car my 96 egt that im running this year is alot faster. yes un hook the sway bar completely just unbolt both sides and let it hang there it wont get in the way this will reduce wheel spin on your driver front and loosen up the car alittle. if u run 3/8 or bigger i would suggest running 195/60/15 if your running 1/4 or smaller then keep the 14's on there. i run tire pressures at 30lf, 35rf,40lr,40rr. at my track we have to run pressures 30 and above
Discussion Starter #3
thanks alot......just wondering but you run your pressures that high huh? is that kind of the "going rate?"
thanks
thanks
it just depends on your track rules weather you can run lower pressure's but at my track and others in the area have to have atleast 30lbs for safty reasons, it would be nice to be able to run lower pressures and tubes but they check pressures after each race
Discussion Starter #5
yeah we dont have tire presssure restrictions......got any good recomendations for me now? lol thanks alot
I run a 91 EGT and run air pressures as follows
LF-25 - 28
RF-30 - 32
RR-32 - 35
LR-32 - 35
I usually start there and work with the track as it changes through out the night. I hope this helps you out.
Redlined Man
Discussion Starter #7
thanks much.....ill start there. I got 2nd this weekend(to a neon). THe car seemed to handle real well......thanks
Dont feel bad thats what I got 2nd to also at our last race. Hopefully that will change with some setup I have done to my car.
Redlined Man
hey wanted to get an update on how your season was going with the ZX2? I finally found a 98 ZX2 yesterday and start the building process today! Have a few big races left in the season here and i hope to get it done in within two weeks or so, with the biggest obstacle being the roll cage. Other than unhooking the sway bar, have you made any other set up changes during the year?
redlined man, i think i emailed you on youtube, im from california, you are the one with the green 26 car?
1 - 10 of 10 Posts
