97 Tracer- can't eliminate pulling to the right | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by ethangsmith, May 13, 2016.
  1. Intuit
    Intuit FEOA Member
    7,490
    902
    Southwest Ohio
    Despite all the pulling and pushing I could never tell that a ball joint was shattered until I unbolted it from the control arm. The bottom half fell-off. o_O My only clue was the "shifty" maneuvering and driving behavior. (at times occasionally worse than others)
    rbailin likes this.
  2. ethangsmith
    ethangsmith FEOA Member
    717
    13
    268
    Manheim, PA
    Good to know. I don't think that's something I replaced on the Tracer yet. I'm wondering what new ball joints and rack bushings would do. I get a knock in the left front when going over bumps, but when we poke, pry, and prod everything nothing seems wrong. I hope it's not one of my tie rods failing again already! I even use the Motorcraft brand parts!
  3. denisond3
    9,956
    2,716
    I could suspect a bad rack, one where the spindle valve had something clogging it or had a crack.
    If you disconnected the serpentine belt, to stop the p.s. pump and the flow of p.s. fluid, I would think it the tendency to turn would go away.
    Pizzaman5000 likes this.
  4. ethangsmith
    717
    13
    268
    Manheim, PA
    I keep suspecting a bad rack as well. There doesn't feel like much boost sometimes.
  5. copcarguy
    copcarguy FEOA Member
    1,983
    848
    263
    Northeast PA
    Has the car even been put on a frame rack? Maybe it's crab walking a little bit. While you say it's never been in an accident because all the vin tags are there it doesn't mean it wasn't jumped in the air like the General Lee.
  6. Intuit
    Intuit FEOA Member
    7,490
    902
    Southwest Ohio
    Interesting. What do you think about this test ?
    Jack the front-end up. (Chock the rear wheels.)
    Center the steering wheel.
    Start the car.
    Observe steering wheel movement, if any.
    Move the steering wheel slightly and let go.
    Recenter the steering wheel.
    Move the steering wheel slightly, this time biased in the opposite direction and let go.
    Good test or bad test ?
    In theory, if the rack is biased, would it push the wheels to the left or right ?
  7. ethangsmith
    717
    13
    268
    Manheim, PA
    Anything's possible I suppose. I've been all over this car and I've yet to find any signs of abuse. It was adult-owned since day one from what I was told, and it certainly looks it. All the body gaps around panels are even side-to-side too. No tight or wide gaps anywhere and no turned bolt or nuts anywhere either.
  8. ethangsmith
    717
    13
    268
    Manheim, PA
    I like the rack test idea. It should make any bias very apparent by the motion of the wheels.
  9. denisond3
    9,956
    2,716
    One of the big values of these forums; when a member has a mysterious problem, and hopefully solves it - and let us know what the fix was.
    Because whatever problems your car has, mine might have them some day.
    copcarguy likes this.
  10. ethangsmith
    717
    13
    268
    Manheim, PA
    Agreed. That's why I'm here appealing to the masses and giving detailed info about what's going on and what's been done so far. I'm going to have to think about my next steps over the next few days. Keep the ideas coming! It's helping me devise a plan of attack on the car.
  11. ethangsmith
    717
    13
    268
    Manheim, PA
    I bought a pair of Motorcraft ball joints and I have a set of the polyurethane rack bushings on order. Doing more experimentation, I noticed that one of the rack bushings is moved out of position. I had my wife start the car and turn the wheel back and forth while I watched for rack movement. Well, it moves! Up, down, in, out, left, right. Not a ton, but enough.
  12. denisond3
    9,956
    2,716
    I know that situation. I hope your rack bushing nuts are not too rusty. Thats the only thing making it a chore to replace the bushing.
  13. bent_rod
    bent_rod FEOA Donator
    1,566
    229
    213
    Kansas City
    Just throw this into the thread, not that it may apply to your car but just something to keep in mind.
    Within a four week time period the car started to pull to the left. It also was as you said above "feels like it's fighting itself as it goes down the road". The tires had no tread wear to speak of with only 7,000 miles of use but had been on the car for 5 years. The back two tires did have some slight closely spaced cuping on the insides next to the edge. Alignment was good, pressure good, new ball joints and all new tie rod ends plus new quick struts on front. Starting at 70 mph the car felt like it had square wheels. At low speeds all was normal.
    A new set of tires fixed everything. Old tires were Wally World Douglas. Had many Douglas tires before and never a problem.
  14. buzzyj
    buzzyj FEOA Member
    172
    4
    178
    Binghamton, NY
    My 2002 Escort SE was bothering me for a long time; because it was drifting to the left all the time. A smart mechanic finally rotated the front tires, and it's been going straight ahead fine, ever since!
  15. buzzyj
    buzzyj FEOA Member
    172
    4
    178
    Binghamton, NY
    Oops! I should have said the mechanic rotated the front wheels with the tires on them. Sorry about that.
  16. Intuit
    Intuit FEOA Member
    7,490
    902
    Southwest Ohio
    Don't know about you, but I rotate my tires every time I go for a drive. {drum-smash!} ;)
    Yeah we know watcha meant Buzz. :)
  17. scotsho
    scotsho FEOA Member
    12
    63
    bent_rod, rbailin and denisond3 like this.
  18. ethangsmith
    717
    13
    268
    Manheim, PA
    Update:
    I still didn't get the rack bushings or the ball joints in. However, I cracked ANOTHER rear sway bar end link. These are the heavy duty MOOG "problem solver" links too. I called MOOG and they told me that it was due to improper torquing by the garage. They had them so tight the rear could not flex properly and it was causing issues. I bought some cheaper generic rubber end links and had them put on and then I hand torqued them perfectly evenly. Going down the road the car seems much more "planted" and firm. But it still pulls right. On inspection, we found a torn and damaged rack bushing, so I think that's going to be at least part of the issue. I also ordered new front complete struts. I am starting to get an occasional clunk from the strut bearings at the tops of the strut assemblies. It's time. So in the next few weeks, the rack bushings, ball joints, and complete struts will be put on the car.
    denisond3 likes this.
  19. marclar
    8,833
    497
    383
    seabeck WA
    if your numbers are green on the screen, and it pulls while driving, that means you have something moving as the suspension is loaded... look for squishy rack bushing, ball joints, control arm bushings, wheel bearings, sticking brakes, and even a bad tire will cause a pull.
    start by taking the right tires and putting them on the left of the car. if there is no change then you need to get under it and start prying on shit to find whats loose.
  20. ethangsmith
    717
    13
    268
    Manheim, PA
    I've done the tire rotations already. No change. Even tried different brands of tires. No change. We've pried around at the shop and no dice. But this morning the car should be getting new front complete struts, new rack bushings, and new ball joints.
