I am all ready to change the transmission oil (5sp manual) in my wife´s 97 Escort, but have two problems:
1. Owners manual says to use Mercon/Dexron, but factory workshop manual says to use 75w90 gear oil. Which is better?
2. To replace transmission oil you need to remove vehicle speed sensor. The VSS is located down behind the engine. I can barely get my hand down far enough to even touch the top of the VSS. Is it possible to remove this little critter without removeing a bunch of hoses? Does not look like I can get to it from underneath either. Anyone done this?
