I am in the process of swapping an engine and transmission from a 1997 LX into a 1999 SE and have noticed that the 97 has a kickdown cable going to the transmission. After reading on another post that the 1997 has the kickdown cable and the 99 has an electronic kickdown.
My question is, can I hook up the cable kickdown and disable the electronic kickdown? Or will I run into computer control problems.
Any info or thoughts on the subject would be helpful.
I have both engines out and am ready to do the install, just need to know if I need to swap transmissions before I put it in, I'm assuming the transmissions are interchangeable.
