1 - 2 of 2 Posts
The motor just blew in my LX wagon & my friend found an EGT that had been rear ended but the engines fine. I know that to put the 1.8 in my wagon i got to swap the whole powertrain & everything, but does it all bolt directly in or do I have to make some modifications?
I didn't have to modify anything when I had to use a LX body. Just used everything GT (whole wiring harness, ECU, trans, sway bars). When I swapped, I pulled entire interior and wiring harness. I stripped both car completely, refinished all sus. comp. when removed, and the only things that stayed in both cars were the hard brake lines and firewall sound mat. No mods. for changing trannys either, just use all necessary parts for the particular setup ie.-getting the right pedal set, slave cylinder(manual), trans. cooler(auto).
1 - 2 of 2 Posts
