Trying to help a friend out but finding and fixing this.
The radiator fan runs as soon as the key goes to run position, engine running or not. It doesn't run with the key off.
I have searched around and found the A/C high pressure cutoff switch next to the radiator on the drivers can go bad and cause this. I unplugged it like said and the fan still runs. I unplugged the low pressure one too and it didn't help. If I remove the 40a fuse or the relay in the junction under the hood the fan stops. I looked around to make sure the fan wasn't wired in directly from a old owner and it's not.
Also we have a snap on scanner at work and the coolant temp sensor seems to be working right but the car never warms up because of the fan always being on.
I want to check the high and low speed relays under the hood but have to find them first. How do I check them? Not much for the electric end of things. Or if anything else can cause this let me know.
Thanks
Thanks
