Hi. I have a 94 1.9l escort that had been running fine until I got home the other night. Now it won't start. It has new plugs and wires, I've confirmed that it is getting spark. You can hear the fuel pump and I pushed in the schraeder valve while someone was cranking it to confirm that it is getting fuel. I've checked the inertia switch and it seems to already be pressed down as far as it can go. What else? I see a lot of ignition switch problems but none of the common symptoms apply as I am getting both fuel and spark. The intake tract is clean. ECU? I know I am getting fuel up to the rail, I haven't pulled the injectors yet to see if they are actually firing. I don't have a fuel pressure gauge so I can't tell what the pressure is but it appeared to be plenty. Thanks in advance for any advice.
