1 - 8 of 8 Posts
OK here's a quick rundown of my problem.
MY CAR
I have a 1993 LX Wagon w/ 1993 BP Engine swap
1994 EGT 5spd transmission
1993 Escort GT Dash Harness swap
cruise control [previosly did not come equipped]
tilt column [previosly did not come equipped]
etc. etc. etc...
120MPH non-tach Gauge Cluster from 95 LX
THE PROBLEM
when i installed the cluster mentioned above,
my fuel gauge is pegged out
half the lights work in the cluster
when i turn my high beams on my turn-signal indicators light up very faintly although the indicators work properly when i turn the lever either direction
my check coolant light stays illuminated constantly [coolant is full i checked it]
speedo works fine [obviosly not an electrical prob]
MY QUESTION
i have searched all over FEOA and i can't seem to find any wiring diagrams so that maybe i could repin the harness.
so are there any?
since i now have cruise control do i have to use the GT cluster which i no longer have [long story, didn't think that i would need it!]?
or can i just repin it for me repinning it would be easier than trying to find one since there are no EGT's in any junkyards close to me.
I like the cluster with out the tach because i already have one. but if i have to change it i don't mind.
any input is greatly appreaciated!!!!!! THANKS IN ADVANCE!!
Discussion Starter · #2 ·
19 views and no comments???!!!
the dash harness has the pin outs for a EGT tach cluster. Find a 1993 EGT tach cluster, take it apart, and swap in your speedo/odo if you want to keep the milage correct.
either that, or buy a 1993 ford factory manual and repin it for your cluster.
i was looking for an "easy" way out of this without spending any money but i thought that maybe someone had a diagram that i could possibly use but i guess i'll try to find a EGT cluster
i guess you right for now i'll just go with it for now till i can find me a cluster. thanks anyways
Discussion Starter · #8 ·
figured asmuch
1 - 8 of 8 Posts
