1 - 2 of 2 Posts
I'm having a problem removing the brake drums on my escort. I've taped them with a hammer and that didn't help and yes the parking brake is off. There is no screws holding them on. There is a hole where I can insert a screw/bolt to remove them. Does anyone know what size screw/bolt it takes? Thanks.
I wish I could remember what size I finally found. I think it was a pair of 10mm or 12mm bolts that finally did the trick. I'll verify that later today.. I keep them with my lug wrench.. it took me a while to get the right size.
Be warned.. it took a great deal of torque on those bolts to get them to move the drum.. if I remember correctly, I ended up using my friend's impact wrench in the end.
In any case.. I'll get back to you on that.
1 - 2 of 2 Posts
