Recently replaced the automatic transmission in my 93 LX with a pulled one that was listed in the parts yards system as having 70000 or so miles on it. I didn't believe it myself but the fluid that was in it was nice and clean and the transmission shifts great. However it seems to have an issue with the 2 to 1 downshift in that if the transmission is still in 2nd gear when the car stops the engine will stall out, but if i slow down enough to let the trans shift back into first gear before it stops it is fine. Is this a symptom of the kick down cable not adjusted properly? Or is it more of an internal problem with the transmission either with the shift solenoids or some of the internal mechanics of the transmission? I tried searching both here on the forum and on the web itself and wasn't able to find anything about this. I ruled out vacuum issues as I replaced the vacuum hoses and also ruled out ignition as everything from the coil to the plugs is new as well. Could possibly be a fuel issue but I doubt it as the filter is newer and the fuel pressure is within spec. Also a new O2 sensor, newer catalytic converter(original one had a damaged casing). Any help is appreciated. - Peter
