93pittescort said:
This car has auto trans. After the car is at operating temperature it will not accelerate. From a stop it takes like 10 seconds for it to start to come up to speed (accelerator on floor). The car has new wires, and plugs, and I haven't seen any misfire from the wires. I have sprayed the TB with TB cleaner, and I still have an issue. I haven't found any vac. leaks at all. What should I be looking for?
I'll assume from this that everything functions correctly when cold?
Do the engine RPM's respond to the accelerator properly when warm, or is it very sluggish?
If RPM's are responsive, but acceleration is not, check transmission fluid. This is exactly what caused Me to replace My auto tranny with a 5 speed. It would function perfectly when cold, but after warm up, nada. turned out that the tranny was burnt, and once everything warmed up, the clutch packs didn't have enough grab.
If the engine responds sluggishly when warm, but is responsive when cold, check for intake and vacuum leaks, check plugs and spark (failing coil-packs can be a pain to diagnose). And don't forget Ben's list as well.
