1 - 4 of 4 Posts
i bought a 93 gt recently and i have a 91 that i bent the frame at home. the 93 is having trans issues, which i know exactly the problem, and the engine leaks a lil oil. anyways, the 91 i built up from a frame, rebuilt the trans, rebuilt the motor; basically everything works right with it. well i will be getting ready to swap the powertrain over and kinda want to do its harness as well but i know i wont probably have the time for that. i have read that there are differences with 93-94 vs the 91. if i swap the powertrain and computer will i have any problems? or do i need to also do the harness?
i do know for a fact that the horn circuit is different on the 93 since i takes a 30a fuse in the engine box.
Who cares about the horn. If it is just the engine going in then they are all setup the same. The only thing that might be different are senser plugs and sensers are easy enough to swap over.
1 - 4 of 4 Posts
