Fuel pressure is good and injectors work OK. Spark is good but don´t know if timing OK (electronic ignition system without distributor). New timing belt had been working fine. When I crank, not a single explosion. Tried after drying out cylinders, switching pump off and on, all without success.
Problem started with loss of power, following gas fill-up. Replaced spark plugs. Could water in gas cause total non-combustion? Could malfunctioning of any of the sensors cause total failure? Will appreciate any help anyone can offer.
