92 escort gt | Ford Escort Owners Association (FEOA)
92 escort gt
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by Zuggycow, Apr 3, 2010.
  1. Zuggycow
    Zuggycow New Member
    10
    Kansas city, mo
    Ok I just got my escort and it's running rough, on some days the car drives like a bat outa hell but other days i feel like I'm driving miss daisie , when I start the car and rev it up it putters and vibrates a litte from 500 to about 1700 rpm in nuetral and then after that is fine but when I'm just idling at a stop light or something like that the car will idle at 500 rpm and lower and start shaking and vibrating really bad and almost die, if any one has any info plz email me preferably or post either is cool thanks for any help u can give me
  2. silverton
    silverton FEOA Member
    2,719
    288
    Seattle, WA
    Check for any intake leaks. The intake pipe is crone to cracking and separating where it accordions.
  3. Zuggycow
    Zuggycow New Member
    10
    Kansas city, mo
    Ok cool thanks I'll check that out asap
  4. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    If you need one, I have a perfect one I'd be willing to part with.
  5. 96_2dr_panel
    96_2dr_panel FEOA Donator
    754
    176
    Stillwater, OK
    Also, check the pcv valve on the valve cover it could be bad and it will make the car idle wacky.
  6. Escort92Man
    Escort92Man New Member
    1,117
    Tacoma, Wa
    it COULD also be a sticky IAC valve, little cleaner down there let it sit start it up there clean, but my money is on the split intake tube at the accordion part.
    you'll get her figured out between PCV valve or intake tube split check those first, if that isn't it try some carb cleaner on the IAC.
  7. bluebronco69
    bluebronco69 FEOA Member
    403
    166
    Oregon
    IAC is in the throttle body right? i think i need to do this to mine, sometimes the idle will dip to 400 and then go back up to normal.
    no vacuum leaks.
  8. Zuggycow
    Zuggycow New Member
    10
    Kansas city, mo
    Well I feel like an idiot I was looking at the intake hose and all underneath there is ducktape all underneath it so I'm taking it ther is either splits or cracks cause it's pretty thick on the ductape so Ty all on that info I'm still gonna check that valve, and on that IAC I'll check that on my day off
  9. Escort92Man
    1,117
    Tacoma, Wa
    ok for sure intake tube split cool, just wrap it in more duct tape for a temporary fix and enjoy her! good opprotunity to upgrade to a nice metal cold air intake or something! ;)
    the IAC is on the bottom of the TB and has the hose coming from the black box to it, idk why it's gotta be an external IAC and not incorporated in the TB but yeah it's easy to clean at least! take tube off, shoot some carb cleaner in there cuz it's got a mild lubricant in it reconnect the black hose and start it up so it sucks the cleaner through it and cleans it and lubes it good
    glad you found your issue! :D
    and my car also does the down to 500 rpm then up to 800 idle if you wanna stop that you gotta play with the throttle body air bypass screw, I had mine perfect once but upgraded to the 4 wire TPS auto TB and never bothered to get it perfect, out too far and it constantly idles high too low and it lugs out so I just put it all the way in and let the IAC regulate idle.
  10. Zuggycow
    Zuggycow New Member
    10
    Kansas city, mo
    Well Ty all I have a project now for tuesday and Ty dude for that info on the TB that was a quil fix it's gonna take me a bit to get it perfect but so far it's working better than it was
  11. Zuggycow
    Zuggycow New Member
    10
    Kansas city, mo
  12. Escort92Man
    1,117
    Tacoma, Wa
    good glad I could help dude! enjoy the ride!
  13. Zuggycow
    Zuggycow New Member
    10
    Kansas city, mo
    If u have any info on how to squeeze out some extra performance or a good place to get after market parts or just swap pieces from another engine or whatever it would be greatly apreciated and Ty all again for the great info
  14. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    run 93 gas and put your timing at 16-18*
  15. Escort92Man
    1,117
    Tacoma, Wa
    cut intake manifold mod, 4 wire TPS, kia fuel injectors, modify your exhaust and punch it out to at least 2 inch but no bigger than 2 1/4 for N/A, upgrade to the B code or K code VAF, get a cone filter, she'll purrr then!
  16. Zuggycow
    Zuggycow New Member
    10
    Kansas city, mo
    Ok first off Ty all for the info the car is running like a beast it's never sounded better and it's fast that's all there is that can be said is that car is insanly fast for no after market parts but..... I got a new problem now... I have noticed for a while that the car had been lagging in geting into gear and stuff likethat and Noe tonight I was driving on the highway I was losing power and by the time it got really bad I was in 5th gear and only doing 35 mph and it was trying to go up to 7k on the rpm .. And then it lost all power and I had to coast off the highway .. The engine it's self is fine and the timing belt and all that is fine but the car won't move i would but it into gear and it would continue to roll down the hill and stuff like that(and earlyer in the day I had noticed it would go way up in the rpm an then drop down and I smelt a rubber or plastic burning smell) if anyone has any info to help me out that would be awsome and Ty again for every one that helped on the engine getting it fixed before
  17. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    Sounds like you smoked your clutch, time for a new kit. It'd be a good time to take care of the rear main seal, you don't want an oil leak near the clutch.
  18. Zuggycow
    Zuggycow New Member
    10
    Kansas city, mo
    It's a 92 with 326 thousand original miles and the factory clutch so I guess I can't be to bummed out (that's the answer my uncle gave me to so Im guessing that's what it would be lol) well thanks man I guess this gives me a good reason to put a performance one in it now with out feeling bad either ;) lol
  19. racethisescort89
    racethisescort89 New Member
    2,391
    In your closet watching you secks!
    get a ford probe clutch 2.2L i beleive its the equvilent to a Stage 1 and its direct bolt on for the EGT
  20. Zuggycow
    Zuggycow New Member
    10
    Kansas city, mo
    Sick that's awsome man thanks I'll check that out
