92 EGT - No A/C Power? | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by bs0d, Jul 30, 2011.
  1. bs0d
    bs0d New Member
    34
    My AC stopped working, and the light no longer comes on when you press the AC button... I didn't see any directly AC related relays or fuses under the hood.
    Anyone been through this? Whats likely the issue? What are the steps to fix it?
    Thanks
  2. Loser_Cruiser
    Loser_Cruiser FEOA Member
    256
    268
    Bellingham, WA
    If your having the same issue as B-Rad in the other current ac problem thread I can give you the same deal on the six pin under hood relay, I'm going to the junkyard on Friday. Let me know.
  3. B-Rad
    B-Rad New Member
    14
    If I may... wait until I get the part and if it fixes it I'll brief you on what my problem was and what fixed it. If it was sent out yesterday I should get it Thurs or Fri. I know not having AC sucks!
  4. bs0d
    bs0d New Member
    34
    I will monitor, thanks for the offer Cruiser. I will hold off for now. Thanks
  5. B-Rad
    B-Rad New Member
    14
    Thanks for getting me the relay loser_cruiser but unfortunately it didnt fix the problem. Either the relay I got is bad as well or there is a problem with the ground in that circuit. Atleast thats my guess. My AC works if you bypass the circuit and just hook the compressor to the battery. I'll keep you posted.
  6. Loser_Cruiser
    256
    268
    Bellingham, WA
    The Relay should be testable using a 12volt source and a continuity meter. Of the cars I looked at it appeared to be in the best condiotion and not tampered with previously.
  7. bs0d
    bs0d New Member
    34
    I swapped a relay with a friend and it didn't fix mine either...
    I notice the RPM's take a dip when I turn on the blower, but I'm not sure that confirms the AC compressor comes on. Plus, still no light next to the blower knob when the AC button is pressed.
  8. B-Rad
    B-Rad New Member
    14
    i have the same problem. Hook your compressor directly up to the battery and that will engage the clutch. This is how you can test to see if the problem is your compressor.
