ok its ben a while since i anounced a new mod so. tired of melting brakes on you 91-95 escort. heres the deal. you kneed a set of rotors from a 96 or newer escort the rotors are 1 inch bigger in diamiter than the stock ones.
but its not that simple you also will kneed the calipers and calipers mounts as well. also your stock rims wont fit you kneed to upgrade to a set that will fit with the new brakes. its a prety basic mod and fairly cheap. just replace all the parts with the newer parts. bleed the brakes aqnd your all set.
sorry i didnt have time to get more into this one.
