1 - 7 of 7 Posts
1989 LX Wagon
Discussion Starter · #1 · (Edited)
Bought this 89 Escort LX Wagon a few days ago, 68k miles.
Issues:
Coolant leak
oil leak
loose serpentine
damaged front bumper
damaged rear bumper cover
driver side door dent
damaged headlight (still works)
cracked dash
Pros:
new alternator
new starter
new battery
new serpentine
fresh interior
68k miles
Fixed the coolant leak yesterday. Plastic piece on radiator broke off so I drilled a slightly larger hole and pushed a barb through it. Applied epoxy on the outside for extra seal. Also flushed the filthy overflow tank.
Previous owners had been overfilling the oil tank and I assume blew out the seals. So hopefully sometime this week I’ll get around to replacing those.
Automotive parking light Automotive side marker light Car Wheel Tire
Automotive tire Motor vehicle Automotive lighting Tread Tire
Automotive lighting Automotive tire Motor vehicle Alloy wheel Bumper
Tire Wheel Vehicle Car Land vehicle
Automotive tire Motor vehicle Rim Gas Machine tool
· Administrator
I'm sure that will hold for a while, but like I said,... that barb comes free with a new radiator. lol. the material is glass reinforced thermo plastic, epoxy does not really adhere to it.
Those barbs are notorious for breaking. So much so that Dorman created a solution.
Tool Auto part Font Magenta Fashion accessory
The solution you have will hold until it doesn't, but longer term (assuming you don't want to fork out the $$ for a new radiator for now) if/when that fails, use the Dorman.
1988 EXP 2.0l H.O on bike carbs.
I’ll have to add this to my bag of tricks. Thanks for the amazing find
1 - 7 of 7 Posts
