1 - 6 of 6 Posts
New/old member here... haven't been on in so long, I forgot my user name!!!!
My 89 LS temp and fuel guage suddenly quit. Was fine earlier today, now they are not.
Any ideas where to look?
Do the idiot lights still come on when you turn the key? If not then likely a fuse. On the 90 there is a 5 volt regulator in the cluster that can go out. At least on mine there was.
EDIT
Nope, it was the wifes Volvo I did that on.
Are the gauges illuminated when the headlights are on? If not it's definitely a fuse. I'd give them a good checking first.
There are a pair of 15 amp fuses and a 5 amp that power the instrument cluster. I can't seem to find which one exactly is used for those two items though.
I hope you have a tilt column, as it seems like you need to pull the instrument cluster. The tach and speedo are a PITA, but it comes out fairly easily. I'd need to tear mine apart again to see exactly how it's built, but it could be an internal connection within the cluster.
1 - 6 of 6 Posts
