I agree, after peak HP, increasing the RPM's goes to the DOWN side of HP, although a LITTLE is aok, but NOT past recmd redline for sure.Bear45-70 said:Why is it that people think if you rev a motor higher it will make more horsepower? They can't and don't and all the extra rpm do is abuse the motor. Removing the rev limiter will not give your engine the horsepower of the GT's HO motor. The CFI motor has 90 horsepower at 4600 rpm and the HO (GT) has 110 at 5400. The reason for the difference is not rpm, it is cam, fuel injection system, etc. Revving more than a couple of hundred RPM past peak horsepower nets your LESS horsepower. It's called a horsepower curve for a reason. :roll:
If ya read Hot Rod magazines, etc you often find a curve/chart that gives you the HP and/or Torque at EVERY RPM.juggalo said:for the 2nd gen 1.9's it's [email protected] and 108 ft [email protected]
was that the info u wanted larry?
I thought the op's escort was a 1988, last time I checked a 1988 1.9 was a first gen.juggalo said:for the 2nd gen 1.9's it's [email protected] and 108 ft [email protected]
bear, i was answering this question right hereLariRudi said:Has anybody ever seen a published HP or TORQUE curve for our Gen 2 1.9's?
I guess I wasn't very clear, what the hell has that question have to do with the op's original question for this thread and why does he just go look like the rest of us do?juggalo said:bear, i was answering this question right hereLariRudi said:Has anybody ever seen a published HP or TORQUE curve for our Gen 2 1.9's?
I wasn't clear either; didn't mean to hijack, but we ALL make mistakes; including the guy that stated the subject car is a 1988; no, it's a 1989.Bear45-70 said:Why is it that people think if you rev a motor higher it will make more horsepower? They can't and don't and all the extra rpm do is abuse the motor. Removing the rev limiter will not give your engine the horsepower of the GT's HO motor. The CFI motor has 90 horsepower at 4600 rpm and the HO (GT) has 110 at 5400. The reason for the difference is not rpm, it is cam, fuel injection system, etc. Revving more than a couple of hundred RPM past peak horsepower nets your LESS horsepower. It's called a horsepower curve for a reason. :roll:
Unless you or someone else has modified it, it doesn't have a carb. Just as has been said before an '89 Escort wasn't made with a carb. It may be throttle body injected which kind of resembles a carb, but they are two totally different things. I think the last of the carbed Escorts were made in '86 unless I'm mistaken. I own 2 '88's and both of them are throttle body injected as were the '87's.BigZ2004 said:Ok well the car is an 89 and it is carburated so the first guy obviously knows nothing about cars considering i own it and drive it i know what it has and the reason i am wanting it to rev higher is because i race it at a dirt track and i am having to shift to 3rd gear because it hits the limiter and i only need a few more rpms to prevent this
Sorry I can't help you with that, but my guess would be you'd either have to change ECU's or have the current one reprogrammed.BigZ2004 said:ok well my apologies to the first guy then i obvioulsly know nothing about it i always thought it was a carb so what can i do do get some more power
