89 Escort GT driver side seat belt track replacement . | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by ricksgt, Dec 15, 2019.
  1. ricksgt
    ricksgt MY 1989 Ford Escort Terlingua GT .
    627
    154
    193
    Biloxi ,Mississippi.
    Hello All,, well ,,things happen and it happen today ,, let me change that ,its been going bad for sometime now over the last few months ,at times , it would stick when it came back to you as the door was shut , moved and worked great when you open the driver side door , but now its not working at all the motor is even dead ,no sound at all . The good news about this ,is that I have another set ( used ) out of my parts car I got a few years back ,so I am hopping all is good with those parts ( seat belt track and motor ) ,, I'll try and post a few pictures tomorrow . :thumbsup:,,,electric seat belt track ,,pain in the butt . But I am surprised it lasted this long ( over 30 years now ) . car has over 200k miles on it .
  2. denisond3
    10,164
    2,855
    Good Luck with the other car's "auto" shoulder belt. When the belt began sticking in my 91, it was warm weather. On cooler days it would not complete its trip. I got the inner panel off without breaking too many of its plastic clips, got the belt track and the motor unbolted from the door opening, and took it apart. The plastic cover on the cable that moves the 'slider' forward and back was cracked - right where the sharpest radius to the aluminum extrusion was. Also the groove in the extrusion was warn noticeably at that point (right by my left temple). While I could clean out all the much, and put new grease in it, there was nothing I could do about repaorong the cracked nylon coating over the cable. And of course the Ford dealer didnt have any inventory; just said the parts were "obsolete".
    So I worked the sliding clip to its rearmost position, and disconnected the motor (as it would still hum for a while, since the slider could not reach the limit switches at the end of the aluminum extrusion. And there was no way to use a passenger side belt on the driver's side door frame.
    Since then, for the last ten or so years, we just hook the shoulder belt to the retaining clip as we get into the car, or unhook it as we get out. Now my 94LX wagon is doing the same thing, as does my 93LX hatch.
    In the junkyards I only found belts that were already stuck halfway, or that had been harvested and were missing.
    ricksgt likes this.
  3. ricksgt
    627
    154
    193
    Hello again All,, I got the old used seat belt tracks out today ,, wiped / clean them up some , laid them out so I could see which was the drive side , the side I needed to change out , the car they came out of was a low miles LX ,88 model two door , picture posted below , the car had been sitting for over 15 years when I got it . The car had engine head gasket issues no one put the time of money into getting fix . Engine was shoot after sitting so long . Anyways here are some pictures ,, thanks for looking in:thumbsup: , I'll post more pictures and info as I get this done in the next week or so , I can still drive the car as I got it ,, and I have a back up car if needed ,,lol,, poke,, :D
    denisond3 and Pyoro like this.
  4. UnexplodedCow
    UnexplodedCow FEOA Member
    7,042
    177
    363
    Central Ohio
    I swapped in manual seat belts to my car; all I had was a 2 door Tempo as a donor, so I modified the plastic bits to fit the belt itself, bent the locating ear on them, and put a small slot to locate said ear, then bolted in using the same bolts as the tracks did. Mine was a 4 door, so I didn't need the belts to be as long. I wound up removing the tracks, and the center piece, which saved some weight in the car.
    Pretty much any 2 door Ford would fit your application, and will bolt in with minimal issues. Once there are electrical or mechanical issues, those auto seatbelts are a problem. They also catch people's hair/heads, and don't really do much for safety (that lap belt sure does).
    austin86, ricksgt and denisond3 like this.
  5. ricksgt
    627
    154
    193
    Thanks for the information on the belts ,, I will look into that ,, need to make a trip to a few junk yards soon . :thumbsup:
  6. marshpoprock
    marshpoprock FEOA Member
    1,924
    41
    298
    Southwest,PA
    Really do not need to swap the entire track just to replace the motor. The motor will unbolt from the track.
    ricksgt likes this.
  7. ricksgt
    627
    154
    193
    thanks for the information :thumbsup:
  8. ricksgt
    627
    154
    193
    Well ,, I got into it today ,,wow what a job ,,still not done , but got it all apart and out the car ,, the old seat belt track and motor ,, the old track went bad , see pictures , the motor is shot / bad too , I got to get things cleaned up and sanded and paint some brackets before putting this all back together , re-install I mean ,, behind the inside panels very dusty and dirty , its been a few years , do it while its apart ,I say :thumbsup:,, no hurry on this project ,I still got a back up car if I need to go somewhere ,,lol :D,,just saying . ;)
    Here are a few pictures ,,yes the back seat has to come out to get that big inside panel out of the car . Good thing these cars are " Hatch Backs ",,lol .
    Old plastic track belt striped out ,so the plastic teeth on the motor drive could not grab it and pull it back all the way back . see pictures :thumbsup:
  9. ricksgt
    627
    154
    193
    :thumbsup: picture of seat belt track motor with part number still on it . :thumbsup:
  10. austin86
    1,124
    378
    118
    Ohio
    nice work as always rickgt. If you need parts for the automatic seat belts I'm sure I still have some, just pay shipping and they're yours.
    ricksgt likes this.
  11. ricksgt
    627
    154
    193
    thanks:D
  12. ricksgt
    627
    154
    193
    doing some cleaning today , found a penny under the carpet ,,lol,, crazy Ford factory worker maybe :thumbsup:wipe the floor pans down too in the back , vacuum what I could get to , lots better now , it needed it , been a while . Also trying to sand and paint a few brackets while the weather here in Biloxi is warm today . Thanks for looking in , will post updates later .
    Take care All ,,and be safe and Have a Great Merry Christmas and Happy New Year :D
    Pyoro and austin86 like this.
  13. ricksgt
    627
    154
    193
    Just a little history on my car ,,I have had it since 1995 ,
    now I just cleaned the face of the penny I found today , its from 1981 ,
    so yes it could have happen , no way that penny could have gotten to where I found it ,unless someone put it there :D,,,kinda cool I think . some lite rubbing with a SOS pad ,
    austin86 likes this.
  14. ricksgt
    627
    154
    193
    Ok,, I'm all done with this project ,,its fixed now :D,,works great ,greased the track real good before putting it all back together ,, yes I had to take the extra track apart and use a bracket off the old track set up ,, the 1988 model is not just like the 1989 model ,, but if it had been a 1988 and half car ( mid year ) 1988 .5 ,,lol,, it would have worked without taking it apart , but taking it apart was good ,I got to learn how it all go's together , so if I have to do the other side one day , " I got this ",,lol,, :thumbsup:,, again I greased the inside of the track really good ,, you would not believe how quite it is now ,and moves really easy .
    Here are a few pictures taken today ,,before re-installing the inside trim panels .
    Take care All and stay safe . ,,,,Thanks for looking in .
    The black plastic ties on the other motor in the picture below - is just for extra protection , on stress area ,when the motor is on , by doing this ,this will help keep good contact with the belt track when moving on the plastic teeth on the motor drive ,that move the belt track back and forth . :thumbsup:
  15. ricksgt
    627
    154
    193
    This is for those who may need it . :thumbsup::D,, very hard to fine this diagram .
    Pyoro likes this.
  16. ricksgt
    627
    154
    193
    Front seat belt track info from center console seat beats :thumbsup::D
    Pyoro and denisond3 like this.
