I used a computer grade power cord, 3 wire with ground shield to make the TFI to distro wire. I cut up an old TFI module I had lying around, soldered the connections up to its blades, mounted it on the distro, and then opened up the harness some to run it over to my driver's side shock tower, where the real TFI resides. It's a very easy mod, just be sure you get high temp insulation on the wire. Mine is said to melt by 80 Celsius (176 F), and it hasn't failed yet. I think it's a little low temp for the application, but am not going to replace it unless it breaks. I'd suggest 120C insulation.
