$50 fixes CEL | Ford Escort Owners Association (FEOA)
$50 fixes CEL
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by wotnartd, Apr 13, 2008.
  1. wotnartd
    wotnartd New Member
    145
    Manawa, WI
    It's bullshirt!
    $50 for a O2 sensor? Holy freaking' crap!
    That is all.
    Anybody else have a little rant about stupid little expensive parts.
  2. Kauai96LX
    Kauai96LX New Member
    1,053
    Kauai, Hawaii
    an o2 sensor for my friends rsx was $300
  3. ford_obiwan
    ford_obiwan New Member
    303
    in canada that O2 sensor is $80 for the cheep one
    and a set of brake pads for the front $ 65 on special
    rubber boots for the front caliper ( pins ) $ 25 with taxes
    and with road salt every thing goes faster
    every year i have to pull front appart to regrease it and clean out the junk so breakes work
    ps its not just the escort my truck does the same thing
    if you clean it 's time and a dab of grease
    or if you dont later it's roters and break pads $$$
  4. wotnartd
    wotnartd New Member
    145
    Manawa, WI
    That blows.
  5. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    13
    338
    Minnesota
    Actully $50 is fair price for a O2 sensor.
  6. EGTERIC
    EGTERIC New Member
    2,417
    Glendale Hts. IL
    50bux is fair mine was like 110 or sumthing for my 4 wire... and it only had about 2000 miles put on it i think b4 the wires melted from being wrapped around my header...
    stupid fukin merlins muffler and brake
  7. wotnartd
    wotnartd New Member
    145
    Manawa, WI
    It was the cheapest.
    It's Bosche, but yeah... it works.
  8. Bone_Head311
    Bone_Head311 FEOA Member
    597
    266
    Port St Lucie, Florida
    If you spend "only" 50 bucks to fix your car. consider yourself lucky.
  9. wotnartd
    wotnartd New Member
    145
    Manawa, WI
    You must have not read my other threads.
    I've completely overhauled the top end of the block, new head and gaskets. ($415)
    And don't even get me started on my other cars...
  10. alscort93
    alscort93 FEOA Member
    1,132
    186
    Webb City, MO
    Where do you get any other brand, I know AutoZone, and O'Reilly's only had Bosch when I got mine.
  11. wotnartd
    wotnartd New Member
    145
    Manawa, WI
    There were some more expensive brands at Advanced Auto.
  12. PonyExpress
    PonyExpress New Member
    4,128
    Bosch makes most of the OEM sensors anyways...
  13. win0857
    win0857 FEOA Member
    1,117
    4
    288
    Connecticut
    Sorry,that answer is wrong.BOSCH is mainly on the german cars,DENZO makes most of the asian cars with some domestic. BOSCH will work on some cars but not on all.I am a ASE L1 and state of connecticut certified emission tech and bosch will not work on toyotas at all.I had problems with all the BOSCH o2's i was putting on toyotas and now use DENZO on all asian cars.WALKER o2's work ok but more and more i find you must use OE manufacturer to keep the CEL off. I buy OEM from the aftermarket for domestic,i have a warehouse that carries DELCO and MOTORCRAFT at 1/2 the price and i have a corporate deal with crysler that gives me big discounts on parts right from the dealer.
    Mark
  14. Andrew_1122
    Andrew_1122 Guest
    776
    my o2 sensor for my Integra was $120. I think my work sells o2 sensors for escorts more then that, around the $80 mark.
  15. IlBrutto
    IlBrutto Guest
    16
    Huh, I've never had a problem with them. We used to get a discount buying the BOSCH universials, installed them in everything that needed it and they never came back.
  16. win0857
    win0857 FEOA Member
    1,117
    4
    288
    Connecticut
    More OEM's are using widebands or air fuel ratio sensors.Bosch widebands do not read the same as the denzo's so the car sets a air fuel ratio sensor code and back it comes.More and more OE is the only thing that will work.The same goes for spark plugs,put BOSCH platinums in a nissan and it will be right back with a po30# code.Iridiums are the only plug that stands up to this ignition system.
    Mark
  17. wotnartd
    wotnartd New Member
    145
    Manawa, WI
    I'm thinking getting a SAFC and going wideband this summer, tune it to perfect.
