phew, i dunno about that. the size of our 1.8s are roughly same size as a 2.0 and to go from a 2.0 to a 5.0pheww...That big of engine in our cars would, well yeh, it would kick ass. but....possibility of it, is kinda small. If u want rear wheel, the engine wont be tilted sideways nemore, so you´d have to find a short block/small block. As for the transmission, well, there would have to be some room freed down the middle of the car. You would never be able to fit a 5.0 and its transmission sideways... As for rear wheel drive, well, thats a little more simpler to find out. The European/japanese/australian lasers have the tx3, which is an all wheel drive turboed escort. U could prolly adapt the rear end from it, but i´m sure a transfer case would be involved in there somewhere too. As for the drive shaft and u joints, well, you´d have to clear a lot of room. I´m sure you could do the rear wheel drive pretty easily, in mechanical sense that is... Basically, just look at how a tx3´s driveshaft is ran and prolly get ahold or atleast make your own gas tank the same specs or better that the laser has. As for exhaust. With the 5.0, if im not mistaken, its dual exhaust so there´s gonna be some crafty exhaust routing taking place there. Around the gas tank, drive shaft, excetera. Might cost some money, but unless ur a good mechanic, leave it to the custom exhaust places.
I´m thinkin the fire wall would have to be pushed back, or the front end extended. a converson of the front end would have to take place because you are no longer with front wheel drive. So you´d have to rig up independant suspension in the front cuz there prolly isnt an easy way to make a solid axle because the engine would be down lower.
As for fitting the engine, you would have to fabricate custom engine mounts because
a) the engine is no longer sideways
b) there is no way in H*LL the engine mounts ya got right now would hold down a 5.0, not even if you customized them
c) they just wont bolt up to the new engine the same as the 1.8 has.
Electrical wise, you will have to know the schematics of the 5.0. New fusebox, or modify the one you have, it would involve remapping everthing electrical, even down to the fuel cutoff switch we have in our trunks.
If its something you are really interested in and have the determination to do it, go for it. Its gonna take a lot of work, a lot of various tools, parts, outside help, but anything is possible. And if u got the right engine, there are lots of possible parts/modifications/superchargers/turbos that will fit the application.
My suggestion, if u truely wanna go for it, go find a scort with a blown engine because everything under that hood is gonna be obsolete be with that new 5.0.
Have you considered just turboing the living piss out of it? Heck, there are lots of performance parts for the zx2/3 engines out there. They dont have a whole lot of hp comin stock, but bore/stroke/mod/turbo or supercharge/ and you´ve got a sleeper.
