4 wire TPS clarification. | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by bluebronco69, Jun 16, 2011.
  1. bluebronco69
    bluebronco69 FEOA Member
    403
    166
    Oregon
    ok
    here we go
    here is the are i am looking, there are 3 pictures.
    i follow the TPS wires down where it meets up then i cut away the tape/loom from the grommet past the TPS wires and about 3 more inches for good measure, still cant find anything.
    if it makes a difference it is a 1992
    i was hoping to find it here so i dont have to run wire all over to the VAF but i can run it to the VAF if need be.... but would rather not.
    [​IMG]
    [​IMG]
    [​IMG]
    here are some pictures that i wrote on, hopefully you can see my notes...
    i tried one wire that is green with a faded looking red tracer, it did not appear to have continuity to the green with red tracer at the VAF.
    [​IMG]
    [​IMG]
    maybe someone can help me. why is this so hard.
  2. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    Its the light green with red wire
  3. bluebronco69
    403
    166
    Oregon
    the one i pointed to in the last photo?
    i saw the light green with red at the VAF, but i cant find a match in the loom.
    does the key have to be on for continuity?
  4. 88scortgt
    88scortgt FEOA Member
    750
    166
    Elkhart, IN
    I finally got a chance to look at how I wired mine up, after 2 days of rain. The LG/R wire is in the harness that runs above the brake booster. If you follow it down there is a "Y" near the wiper motor. You will need to run a jumper wire from that area to go to where the rest of the TPS wires are spliced together. Sorry about the confusion, but I have worked on a couple hundred cars since I did this mod, and couldn't remember exactly how I did it.
    [​IMG]
    [​IMG]
  5. bluebronco69
    403
    166
    Oregon
    THANKS
    that is great
    helps alot
    im sure this will help someone else in the future as well.
    now maybe i can install it tonight if i have enough wire!
  6. bluebronco69
    403
    166
    Oregon
    got it done yay!
    those last pics really helped a lot! i was in the completely wrong area.
    i found the GR/R wire right away when i opened the harness over the brake booster. open it wherever is convenient. them i spliced into the wires for the 3 wire tps, and left the connector on, that way if i ever need to go back i can without more wiring.
    i spent more time scraping the gasket and hooking up the coolant hoses than i did wiring and bolting the TB
    thanks to everyone who helped!
    here is to better MPGs
  7. Gotts2BMe
    Gotts2BMe FEOA Member
    54
    156
    This is helping me as well. Just one quit question will the 4 wire tps and throttle body from a SOHC protege be the same as the egt one?
  8. GravyTrain
    GravyTrain FEOA Member
    43
    11
    38
    Ocean City, MD
    question. does the 1.9 have the same tb? or is it just a auto 1.8?
  9. DrunkinMist
    DrunkinMist FEOA Member
    436
    4
    168
    Lacey, WA
    the 1.9l is different motor and different tb not even close or i would have all the spare c clips i need to keep mine in place. damn 1.8 auto are so rare now at least.
  10. ExodusCheese94GT
    ExodusCheese94GT FEOA Member
    215
    20
    118
    Prince George, British Columbia
    Bringing a dead post back to life, in regards to wiring into vaf, and not having to move any pins on the ecu, I would have to move the required pins on a bp26 ecu though wouldn't I?
  11. denisond3
    9,956
    2,716
    The need to dig into the wiring harnesses of fuel injected cars -at all- gives me nightmares!
  12. DrunkinMist
    436
    4
    168
    Lacey, WA
    Yes if u are using the bp26 yellow ecu repin is needed. I dont have my paper repin handy.
