erg well i guess its not the same as 3rd gen no light green with red stripe , I did take out my gauge faces and i see 2 solid green wires, one is light green and the other is dark . i might have to take a chance on them sometime
96 is not biased off the 3rd gen. If a 2nd gen doesn't come with a tach cluster then the wire probably won't be at the cluster. You will have to get it directly from the computer.
Woh, woh, woh. When you install megasquirt you remove the old computer, right? If so what use is getting a tach signal from the stock wiring that comes from the old computer which is going to be gone?
