1 - 2 of 2 Posts
Worst job i've ever had to do on a car. Can't get to the damn thing. Thought it was under the alternator, but the accessories bracket is in the way. From the bottom, the compressor is in the way. Ended up having to drop the whole accessories bracket, meaning i had to pull the radiator hose to get it off. The pulley is bolted on, under the pulley there's this triangle thing that's pressed on. The Power Steering puller i have wouldn't fit around it, had to have someone else do it for me. All in all, it turned out to be an 8 hour job. Should have had a mechanic do it.
Chris
1 - 2 of 2 Posts
