3rd gen lowering questions - please post pics! | Ford Escort Owners Association (FEOA)
Discussion in 'Suspension' started by MenaceMan47, Jun 1, 2014.
  1. MenaceMan47
    MenaceMan47 FEOA Member
    248
    62
    178
    New Mexico
    I have a 1999 4-door sedan i'm freshening up. I've replaced the front and rear swaybar endlinks and rear swaybar bracket bushings with Energy components and I love how they firmed up the suspension. I recently bought a set of shocks and struts on ebay and want to replace the factory springs. I was doing a tire rotation last summer and noticed the rear springs were cut and welded (previous owner, I assume) so I don't know what the stock ride height of the vehicle is. I'm considering a 2-inch drop kit; I want to replace everything in terms of springs, shocks, and struts, but my car isn't the stock ride height so I don't know how low a 2-inch drop would really be on my car. Comparison pics or before/after pics would be awesome if you have them.
    I'm hoping you all could post your 3rd-gen vehicle pics (those of you who have installed drop kits) so I can get an idea of what's out there and get a better idea of what it would look like. I don't have aftermarket wheels/tires, so I'm hoping to keep a somewhat modified stock look. I have considered going with an aftermarket tire/wheel package down the road, but nothing soon.
  2. TexasTracer
    TexasTracer FEOA Member
    4,694
    16
    188
    Sunnyvale, Texas
    Progress Technology 1.7 in front 1.5 in rear, gave a slight rake, looked good. I believe these springs are discontinued.
    [​IMG][​IMG]
    MenaceMan47 and ar154all like this.
  3. MenaceMan47
    248
    62
    178
    New Mexico
    I really like that; it's subtle but still noticeable. I like the wheels you have; are those older escort wheels? I'm using my stock steelies painted w/black hi-temp engine enamel. They still look pretty good, too.
  4. TexasTracer
    4,694
    16
    188
    Sunnyvale, Texas
    Thank you. Yes they are 93-96 Escort GT fanblades.
  5. MenaceMan47
    248
    62
    178
    New Mexico
    Did you need a corrective alignment after the drop?
  6. 300ZXRB26DETT
    300ZXRB26DETT FEOA Member
    1,012
    21
    288
    PHX, AZ
    Yes since the toe would be off.
  7. MenaceMan47
    248
    62
    178
    New Mexico
    I figured as much... I wasn't sure how drastic a 2" drop would change the alignment geometry. I'm due for a new set of tires anyways, so i'll probably do it all at once.
  8. TexasTracer
    4,694
    16
    188
    Sunnyvale, Texas
    It's always recommended to re-align the car after you lower it.
  9. 4cylinder
    4cylinder FEOA Member
    670
    122
    193
    san diego, ca
    probably one of the best drops which can be done. The red eibach used on the s/r is not too harsh and drops it like this
    [​IMG]
    TexasTracer likes this.
  10. MenaceMan47
    248
    62
    178
    New Mexico
    Gonna buy a set of M2 Performance springs this week; will install the springs on the shocks/struts and post pics before and after install hopefully in the next week or two.
  11. novanutcase
    novanutcase FEOA Member
    2,364
    550
    263
    Mines a '98 SE wagon that I bought a set of Gabriel Ultras and Megan lowering springs for. I finally got all the parts for the job so I will be doing it in the next few days. I'll try and document it as I go and post up a before and after photo along with progress photos for those that aren't so good spinning wrenches.
    John
  12. MenaceMan47
    248
    62
    178
    New Mexico
    M2 springs are coming this week, picked up a set of Gabriel Ultras on closeout months back on Ebay for $69 for the whole set, and will put together the springs and shocks/struts this weekend. Hoping to get everything mounted and aligned before Thanksgiving if my work schedule cooperates :p
    UPDATE: springs are in, should have everything together in the next couple of weeks LowSpringStrut.jpg
  13. MenaceMan47
    248
    62
    178
    New Mexico
    Did the install today; ended up having to replace the outer tie rod ends also. Test drive was great, and my 99 corners as flat as a board. Off to the alignment shop tomorrow for a 4-wheel alignment. I'm very happy with how my 99 handles. Next is tires and black satin paint. Here is a comparison pic of the factory and new spring, along with the new spring installed. More pics to come.
  14. MenaceMan47
    248
    62
    178
    New Mexico
    Here's how it looks now; I ended up having to replace the outer tie-rod ends and the lower ball joints also. Bodywork and paint is next on the list. I test-painted part of the rear of the vehicle with some hi-temp engine enamel, but it's going to stay black.
