Engine - 3.23"(82mm) bore multipliers for end gaps? | Ford Escort Owners Association (FEOA)
Engine 3.23"(82mm) bore multipliers for end gaps?
Discussion in 'Tech & Repair' started by headmn, Jun 26, 2020.
  1. headmn
    headmn FEOA Member
    15
    6
    i have the Haynes Manual for Escorts but not the more detailed Chilton?
    what are the bore multipliers for compression rings Top,Bottom and the
    Oil controler, to find your GAPs? ie.. 3.23" (bore) x .0045 (multiplyer)
    equals .014535" for Top compression ring GAP. this is for a scort 1.9L.
    headmn
  2. austin86
    1,102
    358
    118
    Ohio
    for what motor and year? if its first gen I have a few books that may have that info
  3. headmn
    headmn FEOA Member
    15
    6
    my car and engine is a Ford SOHC, 1995, 1.9L LX sedan....2nd Gen. headmn
    austin86 likes this.
  4. austin86
    1,102
    358
    118
    Ohio
    ok, I don't have the info you are looking for, but I'm sure others have the info you need.
  5. headmn
    headmn FEOA Member
    15
    6
    thx for looking Austin, i would have thought that this would be an EZ reply since we have so many DIY ppl here but..... maybe itz dah shops that do this part ? headmn
  6. marclar
    9,060
    604
    seabeck WA
    dont think ive ever personally heard anything called a multiplier myself, i may just be ignorant to that info.. i have always just put a ring into the cyl, measured gap and filed as required.
  7. headmn
    headmn FEOA Member
    15
    6
    thz Marclar for looking in, i respect your inputs since you are an experienced Escort Resurrectionist. i was simply trying to find out what were the calculations or measurements that ppl were using for the 3 end gaps on a 1.9L scorts' rings.
    i wanted to know the different ways that things are done by the locals. and, having a little time on my hands i thought i would try the bore x .0045(street) thing. however, if you just post the 3 ring gap numbers then i ll be more than thankful. headmn
