1 - 2 of 2 Posts
the ball joints for the 2 generations are different aftermarket part numbers....but they sure do look the same...
does anyone know if they interchange on the control arm?
The difference is in the diameter of the ball joint shaft that goes into the spindle where the pinch bolt goes, and everything else is the same. The difference is about 2-3mm with the 3rd gen one being larger then the second gen. The BG protege has this same thing but it was changed about half way through the model run, like 92.5 i think
1 - 2 of 2 Posts
