1 - 10 of 10 Posts
Just wondering what the compression is on you stock second gen LX'ers.
Last I checked (July 2004), results were as follows:
DRY
Cyl #1: 145 psi
Cyl #2: 150 psi
Cyl #3: 135 psi
Cyl #4: 145
WET
Cyl #1: not done (bad valve stem seal)
Cyl #2: 175 psi
Cyl #3: 150 psi
Cyl #4: 160 psi
Curiously, I'm not even sure what the spec is when our engines were new.
Post if you care.
wha? You serious... I recall seeing the GT compression levels in my old Haynes.
Try a Helms then, or walk into a dealership and ask for a repair manual.
James:
Q Would I lie to you?
A Yes, but not this time.
The specs don't really matter - it's not like I'm gonna do anything about it. I'm just curious how other LX's are holding up.
I've got the haynes manual and the Ford factory manual and neither have that information in them that I can find.
As long as all your cylinders are fairly close, you don't really need to worry that much. Those compression test results don't seem abnormal.
If a cylinder seem low, do the wet test: if your compression increases in the cylinder, worn rings, if there's no increase, check your valve train.
If two adjacent cylinders are low, you've got a blown head gasket, cracked head or block.
If you have abnormally high compression, Don't wet test, you've got carbon buildup in your cylinders.
Discussion Starter · #8 ·
Thanks.
I kinda know the diagnosis stuff. I just wanted to see what everybody else has for compression. Just for fun.
I get lots of blow-by, especially in the winter (presumably most of it is when the engine is still cold) yet I don't think my compression is too horrible. I guess that's my real reason for asking.
Numbers, people, numbers.
Mine were between 190-210 wet, can't remember each cylinder. That was burning oil, with a shaved head.
Soo....my numbers aren't very helpful
suppose to be 175-190 on each cylinder, mine with the shaved head it at around 210 i believe... dont remember.. been awhile since i did it
1 - 10 of 10 Posts
