2nd Gen interior/exterior swap list... | Page 4 | Ford Escort Owners Association (FEOA)
Discussion in 'Interior Modifications' started by horty, Aug 5, 2006.
  1. Kauai96LX
    Kauai96LX New Member
    1,053
    Kauai, Hawaii
    Just a bump for info, i swapped mine in yesterday, and for the cable that controls where the air goes thru etc, the escort one is MUCH too short. you need a pro/mx3 cable for it. the heater control one, however, is just right.
    also, the defogger rocker switch, i havent seen anyone mention that.
  2. 300ZXRB26DETT
    300ZXRB26DETT FEOA Member
    1,012
    21
    288
    PHX, AZ
  3. Kauai96LX
    1,053
    Kauai, Hawaii
    ill posst a pic later. but when you slide the escort HVAC to defog, it activates a swotch. The mx-3 panel (or at least mine) does not have teh switch.
    And my wiring is wack. i can only get fan 2 and 4, or 1 and 3 to work. and teh wiring on teh mx3 plug is very different from the escort one.
  4. 300ZXRB26DETT
    1,012
    21
    288
    PHX, AZ
    You should be able to follow my post on how and where to swap and splice wires, its all there. re-read it. PM me if you still have trouble.
  5. 93LXcort
    93LXcort Guest
    455
    interior
    So far i've got in the wagon..
    Precidia GS front buckets
    Precidia GS rear seat
    Precidia rear console with armrest/storage bin
    323 cupholder/shifter console.
    Precidia rearview mirror
    working on some protogay power folding mirrors in the future
    Has anyone got pics of their precidia console with the HVAC controls at all??
    Im curious to see what it looks like, and the fitment.
  6. PEEWEE91
    PEEWEE91 New Member
    2,068
    New Hampsta
    94 pro mirrors work too, you just have to modify the interiors triangle pieces a little bit
  7. baardoon
    baardoon Guest
    26
    how do you remove the pins, i have the clips removed off the back of the plug but the bastards wont come out., im almost finished with the swap and this is kinda frustrating me!
    _edit- i ended up getting the mx3 plug and splicing
  8. baardoon
    baardoon Guest
    26
    a couple questions,
    i got the mx-3 mirror but am i going to need to cut the headliner? i mached it up and it doesn't sit flush, and i don't want the yellow piece showing, kinda ghetto imo.
    ALSO the heater controls for the tracer hvack seems to be a little too long, it pushes the unit forward and wont allow me to properly secure the instrument bezel, did any one have to modify this?
    ou could also add that the mx-3 weather stripping will fit the escort, you just have too trim(kind of a given)
  9. WhiteKnightEscort
    WhiteKnightEscort FEOA Member
    293
    266
    Anaheim, Ca
    Any one have pic's for Hvac installation
  10. Wilberforce
    Wilberforce FEOA Member
    201
    40
    178
    Northern Utah
    ha ha i put crappy blue leds to illuminate the floor and it looks pretty good. even wired them so they turn on with the park lights. cost me 10 bucks. but to tell u the truth, its something a civic owner would do but hey, they go great when im blasting the techno!
  11. yournamehere
    yournamehere New Member
    244
    Haverhill, MA
    No actual pics of the MX3 console in a second gen? I only want to use the rear part, with the armrest. Is that even possible?
  12. LowriderS10
    LowriderS10 New Member
    246
    What year MX3 seats are a DIRECT bolt-in?
    Also, same question as yournamehere asked above...pics of MX3 armrest? Direct bolt-in? What years?
  13. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    Any seats from a MX3 will bolt into the 2nd gen Escort/Tracer. The rear center console piece is close to bolt in, there is a rear mount that can be eliminated, but you want to use the seat belt guides from the MX3 rear console, the holes for the belts are in different locations. The colors will be different too. The belts should work to, if you want to go black. I have belts from a Protege in my car, and several other interior pieces.
  14. yournamehere
    244
    Haverhill, MA
    Can anyone answer this? I'm curious as well.
  15. 95EscortOwner
    95EscortOwner New Member
    91
    So what do I need to do the MX3 seat swap?
  16. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    just a socket set. Get the seats and rails from the MX3... it is a direct swap.
  17. Skuce
    Skuce FEOA Member
    3,307
    5
    288
    Ontario
    Just to add.
    My MX3 lower dash/hvac swap is super easy. Did it a year ago now for sure.
    -You will have to re-pin your Fan speed plug. Easy with a needle to pop the pins out.
    -You have to do a little finicky electrical work to get the face to light up....and the stock cig lighter wires are a little short
    -You need to use the MX3 cables all around. Escort ones are too short when mixed with the new gear.
    -Get the lower tube bar under the glove box. Ditch the Escort one....and get the fan motor cover panel with the pop pins.
    -Do the cool bracket/mount if you have Vac controlled recirc. I never bothered to do it cause I always have it to fresh air anyways.
  18. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    If you want a heavier shift knob, get one from the 2nd gen. Protege. It is nearly 1/2 lb heavier, over twice as heavy as the Escort one.
  19. 95EscortOwner
    91
    All right thanks Dave94LX. That really helped. I really hope that I can find a nice set of MX3 seats. Can I use the rails from the Escort to put the MX3 seats in?
  20. LOWETGT
    LOWETGT FEOA Member
    5,229
    24
    238
    N. Illinios
    You won't even need to swap the rails. The entire seat is plug and play.
