Engine - 2014 Ford Focus engine and transmission in a 1995 Ford Escort wagon | Ford Escort Owners Association (FEOA)
Engine 2014 Ford Focus engine and transmission in a 1995 Ford Escort wagon
Discussion in 'Engine Swaps' started by 59bruzer, Sep 13, 2020.
can i put a 2014 Ford Focus engine and transmission in a 1995 Ford Escort wagon
  1. can it be done
    25.0%
  2. why not
    75.0%
Multiple votes are allowed.
  1. 59bruzer
    59bruzer Member
    13
    SOUTH FLORIDA
    i have both vehicles and i would like to put a 2014 Ford Focus engine and transmission in a 1995 Ford Escort wagon /// i know it is not a plug & play but can it be done ?
  2. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,531
    1,186
    Vancouver Island, Canada
    I haven't heard of anyone doing it, but of course it can be with enough determination and skill and brains.
  3. marclar
    9,061
    604
    seabeck WA
    anything is possible. seems like a lot of work.. focus is direct injection and everything is electronic. i could see having issues getting it to run due to the CAN bus missing inputs from the other modules.
  4. austin86
    1,103
    358
    118
    Ohio
    Over in the UK they make carb kits for newer ford 4 bangers and standalone ECUs to run the coil packs so one could delete most of the electronics. danst engineering sell some. Might be worth looking into
    zzyzzx and 88ESCORTV6 like this.
  5. pextor
    pextor Moderator Staff Member
    6,004
    839
    Lancaster, pa
    If it's an automatic don't bother. The dual clutch transmissions are junk.
    If it's stick, have fun. The mounts will need to be custom made, the electronics will be very tricky to make work, and you'll need to fabricate an exhaust.
  6. madmatt2024
    madmatt2024 FEOA Member
    9,882
    421
    383
    Upstate N.Y.
    It would probably be better to go full standalone for the ECU unless Ford makes a control pack kit for the engine you want to use. Exhaust is going to be fun given that it's on the back side of the motor instead of the front, no to mention the custom axles that are going to be needed.
    austin86 likes this.
  7. zzyzzx
    15,209
    1,230
    You would be better off putting the 2014 engine into the 1995, and just using the 1995 transmission. If money is no object.
