UnexplodedCow said:
When you have a flat torque curve like that from a low rpm...it's typical that you have a lower lift and duration cam. That cam typically comes on torque peak around 3400 rpm for a 1.9 engine from what I've seen, but you're reaching that much lower, indicating that your head is capable of flowing more air than the valves are allowing. The cam is responsible for opening the valve far enough to flow more. If you went with a higher lift, longer duration cam you'd definitely see more power. From the picture above, it looks like you're using a stock SPI cam. Am I right?
NO ... not a stock cam. However, I have been suspicious of it all along and wonder if the removal of the base circle material to reshape it actually works well. Some people won't even grind them and some will.???
Duration: 264/268
Duration @ .050: 204/208
Lobe Lift: .274"/.284"
Valve Lift: .452"/.468"
Lobe Center: 112
I know the head has ~ 10% better flow because I have a flow bench and did it myself. My thought was that the intake is the kink and it is running out of air.
All that said, however, what I was after was a great low end high torque engine. Hp does very little for this car and application.
Where can I see some dyno charts for a 1.9 or 2.0 engine?
Thanks
