1 - 2 of 2 Posts
I am in the process of putting a 2.0 in a 96 Escort and have a couple of questions. The 1.9 had a fuel delivery line and fuel return line ,while the 2.0 only has the fuel delivery line,what do I do. It also appears that I use the 96 harness and just tap into the injector motor for the rpm swith is that correct? Is there any other things you have run into that gave you problems. This is just an engine swap nothing fancy just need to be done.
Wayne
1 - 2 of 2 Posts
