this is what i have found...# T3/T4 TURBO CHARGER:
# T3/T4 TURBOCHARGER
# Oil Cooled Only!
# Standard T3 4 Bolt Inlet Flange, Designed to Fit most Aftermarket Manfiolds and OEM T3 Manfolds.
# 5 Psi to 20 psi Peak Power performance Output Capability.
# Designed with Standard 5 blot T3 Flange
# Includes internal wastegate port (option to use)
# Designed with 35/38/44 mm Wastegate Port.
# Compressor Specs: 3'' compressor inlet, 2.130'' inducer, 2.755'' major, 2'' compressor outlet, T04B/T4 type compressor houseing, compressor .49 A.R, compressor .50 Trim, 8 Blade Type Turbine.
# Turbine Specs: T3 Type Turbine Flange, T3 5 Bolt Flange, Turbine .57 A.R, 2.205'' Minor and 2.570" Major Propellar, T3 Turbine housing, 2.274" outlet, 12 Blade Type Turbine.
# Can Manifold to use External Wastegate or Internal wastegate.
# Suggested for 1.6L to 3.2L engine up to 150-400HP.
# INTERCOOLER:
# Size : 28" x8" x 2.5" With 2.5' Inch Inlet/Outlet.
# Low Pressure Drop - Large Cooling Area - Easy Install - Tube And Fin Style Intercooler.
# Made from all TIG welded t-6061 aluminum (increase 10-20 HP)
# psi drop under 0.2. other intercoolers usually drop 10 psi, while some are more.
# New style, more efficient than stock intercoolers
# ALUMINUM PIPING KIT:
# 100% Brand new ,Made of 6061 Aluminum. 2.5'' inch diameter piping kit with high quality silicone couplers and t-bolt clamps. The coupler will not split easily+ the clamps will not between the pipe and the couplers, it was 4 ply layer reinforced, not the cheap intake coupler. Mandrel bend for high flow and high horse power and better turbo response power. Same as picture, come with 12x pipie ( 2x straight, 4x 6'' 90 degrees, 6x 13'' degrees ). 24 x stainless t-bolt clamps, 4 x 90 degrees elbow, and 8 x straight silicon hose. Note*: this is not the cheap stuff like all the ebay seller, make high quality, and most complete piping kit.Some Cutting And Modification Required!
# 38MM WASTEGATE :
# All Stainless Steel hardware, Mating weld flanges are 304L.
# 2 Bolt Flange set up for turbo applications
# Incoel base housing with forged stainless steel valves construction.
# Wled-on flanges are include with every kit.
# High temperature silicone reinforced actuator diaphragm.
# Spring Size is 7 PSI.
# BOOST CONTROLLER:
# Allows Adjustable Boost PSI Settings, Light Weight Design To Be Mount Under The Hood. Hardware Is Included.
# Manually Control turbo boost up to 1-30 PSI.
# Made from billet aluminum
# Mounting bracket , hose and all fitting hardware included
# OIL RETURN LINE:
100% BRAND NEW, HIGH QUALITY ALUMINUM.THE RETURN LINE IS 17 INCH LENGTH.
HELPS CIRCULATE OIL FROM THE TURBO TO THE OIL PAN, WORKS ON METAL OIL OANS ONLY.
# OIL FEED LINE:
# 100% Brand New, High Quality, Never Been Used Or Installed!
# The Oil Feeding Flange has Restriction build in, offers proper Oil Feeding to the turbocharger.
# The Length Is 37 Inch.
# FUEL PRESSURE REGULATOR:
# 100% Brand New in the box and high quality.
# JDM adjustable fuel pressure regulator (FPR)
# Make by aluminum . light-weight design, long lasting.
# Package come with all the hard wares and hoses
# Increse fuel delivery by rasing pressure ( increase 5-10)
# OIL CATCN CAN TANK:
# Make out of T6061 Aircraft Lightweight.
# Increase Horsepower and prolongs your engine life.
# Dimensions: length: 7'' X with: 2.5''
# SLIM RADIATOR FAN:
# 100% Brand New , Really High Quality.
# Light-weight Design, and More Durable Than Factory Fan When Increasing Engine Cooling Performance.
# Size: 12'', 2.5'' Thickness, 1250 CFM, 2100 RPM.
# TYPE-S BLOW OFF VALVE BOV+ADAPTER PIPE:
# CNC Billet Aluminum, Dual Stage Handle, High Boost Power,Easy Mount Piping Set Included For Bolt-On.Including Bov Blow Off Value Flange.
# Fast Fesponse One For Low And High Boost Pressure.
